Hi Guys,
I am trying to create a non standard half hemisphere from a network of curves that I have drawn. Do I need more curves for this command to work? Or is there another command that I can use that is better?
Thanks for any help!!
Hi Guys,
Hi Joshua- if you split the green and black curves with each other, you than then use NetworkSrf or Sweep1. It may be that RailRevolve on just one of the split curves and the red curve as the rail will also get you what you want.
3 posts were split to a new topic: Half hemisphere - same volume as box
