Hairline too thin 0.13 too thick solution?
V5
I am printing a 3D printer test sheet I have designed (so no copying the idea !!) , however when comparing the 3D result I need a raster image with lines thicker than hairline and thinner than the next size option which goes 4x as thick ! called 0.13
it makes it look like the crosses touch, I need to show the gap but hairline cannot even create a same darkness line.
Either I need to make the lines same darkness or get a line weight somewhere thicker.
What is the solution ?
the print doesnt quite live up to the stl sent it .! (not my printing)
it even has a base plinth, most odd.
Cheers
Steve
You can type in any line width you want in the print width box in Properties (or the layer).
I never knew that, thought one had to use the drop down.
bet some others never knew that either.
that solved it
Thanks
Steve
