Hi everyone,
I’m a beginner in Rhino, and I ran into this weird problem when creating two connected surfaces. Some advice would be appreciated.
Please check this screen recording: Rhino 7 Problem - Hairline Leak on Surface seam - YouTube
Working file: Issue.3dm (274.9 KB)
Steps:
I patch the 1st surface
I do sweep2 on the 2nd surface
In the rendered view, we can see there is a hairline leak/gap on the seam between those two surfaces.
Note:
I tried networksrf and planarsrf on the 1st surface, but still resulted in the same issue.
I tried all the different settings of the sweep2 (maintain height ticked/unticked, refit rails tick/unticked, etc.) on the 2nd surface, also tried networksrf, but still resulted in the same issue
I made sure the points on that curve are flat, the same heights.
Can anyone tell me what I did wrong here, please? Thanks before.
