Gurvature Graph and Curve matching
What could be said about this graph here,
As i have understood, it displays curvature continuity, but not G3.
So it sets me up for G2 success but, looking at the graph, I wonder why it could not be more “Perfect”
Should I care?
That depends on what your client expects or what quality level you have agreed upon.
For context it was made with Blend Crv and the result looks better then
And i realize that what I have learned about aligning points in a straight line from the opposing geometry does not do anything usefull in this context, but its perfect when the opposing geometry is ither streight or continues into reflex. like the secund half of an s curve.
I guess is related to the fact that 2 curves mirrored to each other perpendicular to tangency creates curvature continuity, Like tangency over center lines
Id like to add, the modern thing is tho have these perfectly circular wheel arches, that was not necessarily the case in the 80s
Curvature:
My realisation that a “higher” continuity is not acheved by alligning more points:
The inbeween tweak of the pints that supports the rule of tangency over symmetry lines, as well as Even point distribution:
@Lagom I guess you might be right about that. I’m not this here professionally, Im just learning.
Here Im trying to see how far along Normal the point needs to move to get the maximum continuity.
About double the normal distance from point to curve normally seems to bring it quite close:
Maybe scroll to the end of this article. Autodesk has many great explanatorials with visuals regarding these things.
just a hint regarding G2/G3. G3 means you match to the “change of curvature”. This means you can have perfect numerical matches, but your overall curvature will easily look bad. For a good G3 match, you need to bring your initial curves/surfaces into good theoretical positions. You simply cannot match any shape in a second step and expect a good flow of curvature. The blend magnifies the difference of your references. A G2 match, can be a better solution, if it’s a difficult position. There is a lot of knowledge involved to be able doing good surface models. But the key is bringing your main surfaces into good relationships, and to see the blend as a proof of this.
Curvature graphs, Zebras, Camera distortions etc are tricks and tools to enhance your human perception, to better detect problems. So, unless you do professional modeling, you should not care too much. For hardcore surface-modeling, Rhino might not be the best choice anyways. Professionals rather use Alias or Icem Surf in this case.
@Lagom Nice! Thanx
Yes this seems to be the very essence and the thing I probably break any time things get out of hand
