This curve shows 0 thickness / width in the X axis ( via Box edit ) BUT the Gumball is showing the curve is not flat ( small red box ) .. Can gumball tolerance match Rhino’s absolute tolerance.. ? I use gumball to show if curves are dead flat and the ones that fall well below tolerance still show as not..
The gumball hides a scale handle only when the object’s extent in that direction is essentially zero (about 0.000001 units). It doesn’t use the document’s absolute tolerance. Your curve is 0.0002 mm wide in X, so the X scale handle is shown.
BoxEdit shows Size X as 0.000 because it uses the document’s display precision, which is three decimal places in your file. To see the actual value in BoxEdit, raise the display precision in **Document Properties > Units**.
To make the curve exactly flat in X, run SetPt, check only Set X, and pick a point on the line’s X position. The scale handle will then go away.
