Hi. When I rotate a simple cube, the axis of the gumball rotates with the object. If I rotate a grouped object, the gumball rotation stays aligned with the construction plane even if I say “align to object.” Does anyone know how to prevent this?
Hi Ziiar- gumball alignment for multiple selections does not survive de-select/re-select. Groups are essentially selection sets of multiple objects… so the answer is, you cannot prevent what you are seeing, I’m afraid.
