Gumball Rhino 8Wip can’t extrude
(in no Solid or BothSide)
by Numbering Value
I Test the wip version that handles gumball removed ;
in This Version
Ctrl
+ drag= extrude (no Solid)
SHift
+ drag= extrude BothSide
But in Numberic modeCtrl and Shift
Can’t work
The gumball works as expected in Rhino 8 SR0 2023-5-16 (Rhino WIP, 8.0.23136.12095)
Maybe you can upload a screen video and a Rhino file showing your problem?
If the curve isn’t planar, the extrusion is not going to be closed.
In new update if we will want extrude numberic +both Side
by shift key or extrude +and NotSolid +numberic
Disable it!
It seems the extrusions are closed when the curve is closed and planar.
I would also prefer open extrusions. If the open surfaces are planar, it’s easy to run the cap command. Deleting faces requires a selection and is more of an effort…
@martinsiegrist - Currently you can make open or closed extrusions from your closed curve by:
- Drag on Extrude Dot = Closed Extrusion
- Drag + Ctrl on Extrude Dot = Open Extrusion
Does that help?
That’s ok for now.
However I’m not sure if it should be the opposite. A simple drag on the extrude dot would lead to an open extrusion consistently.
If the curve isn’t planar, the extrusion is always going to be open.
Drag = open extrusion
Drag + control = closed extrusion
If the curve isn’t planar, ctrl has no effect and the extrusion is open.
