Imagine i select that square block.
With a Specific Alias, I would like to relocate the gumball to the top right corner
with another alias, maybe to the bottom left corner, etc… etc…
Perhaps the scripts posted by @Gijs in this topic may help?
thank you Bobi,
yes, the two script
set_gumball_max.py (503 Bytes)
set_gumball_min.py (503 Bytes)
are doing what I need, except I cannot choose right or left alignment.
I would put this functionality on RH9 wishlist
If you notice, my initial proposal in that other topic is about having “bounding box scale handles” that could be used to scale the object directly depending on which handle is used. It’s super convenient. Combined with Osnap, that becomes the best possible way to scale the selection to fit between other objects.
I can see that very useful for architectural projects that rely on walls and other boxy shapes.
