Gumball Plane Handle Not Maintaining Planar Movement
If I have a curve, after activating the Gumball, I select the point I want to control and I can move it along the directional arrows, but can’t the plane handle maintain that planar movement?
Hi @brvdln ,
The planar handles align to Cplane still when the GB is set to by object and a ctrl pt is selected. I am not sure but I believe this is due to the tangent/normal not being the same plane in both directions on non planar curves. So I’m guessing this is why the planar handles align to the Cplane… but maybe I’m missing something without seeing the curve from your file. I’ve filed RH-95474 for the developers to weigh in. Thanks.
@BrianJ Tomorrow morning, as soon as I’m at the office, I’ll send you this and other files as examples (they’re company-related, so I can’t publish them). Usually I’ve noticed that it doesn’t maintain the CPlane… maybe it’s a bug, but in general I’ve always found it strange that the curve loses its planarity. Also because, as you can see, I create lateral lines every time so I can re-project them onto an extruded plane.
This is just an example to help you understand. I’m sure the curves are on a plane because the inner light-blue curve you see on that wedge lies on the same plane as the external light-blue lateral lines you see outside, which are guide lines that I use.
Just one curve is probably fine to send to tech@mcneel.com or post here. You may also like the Align command with the To Fit Plane option.
File sent. :+1:
Filed as RH-95474 for future reference.
@BrianJ So actually my doubt was correct: the gumball was not keeping the curve planar when I moved it? Could you post the link to RH-95474 and possibly make it public, so I can follow the future developments? Thanks.
Hi Brv -
Your file was linked to a public comment in the item. Making the main item public would also make your file public.
@wim No, then it can remain private. The file I sent cannot be made public.
Best regards,
Daniil
RH-95474 is fixed in Rhino WIP
I just checked now, the Gumball works while maintaining the CPlane. :+1:
