Gumball Move - Shift+Enter Does Not Work, Shift+Return Does
When attempting to move an object in the opposite direction of the Gumball arrow, one cannot use the Enter key. Only Return works. Moving in the direction of the arrow does work with Enter. I believe this is new as of recent builds. Thanks!
can you give some more detail about this? are you on a mac or pc?
I’m not understanding what you are doing… are you using numerical entry?
Hi Kyle,
Thanks for the followup. I am on a Mac. I’ve attached system info along with a screen recording. Unfortunately, the keystroke visualizer doesn’t not differentiate between the “Enter” key and “Return” key but the difference in behavior can still be witnessed. In the screen recording, the first and second moves are confirmed with return and shift+return, results are as expected. The third and fourth moves are confirmed with enter and shift+enter. As you can plainly see, the positive direction moves works properly. The negative direction move, using shift+enter, does not. Only thing that happens is the numerical text field gets cleared. Both shift+return and shift+enter should function identically. Thanks!
systemInfo.txt (11.5 KB)
