Gumball Issue
I have this issue where the gumball is taken over by the Z dimension scale tool. I tried resetting the gumball and the obvious method of changing my angle does not change it. Not having any luck adjusting the gumball settings which I have reverted to default
something is certainly odd… why is your z axis aligned to the x?
blue should be pointing up not left.
Oddly, I flipped the plane back to normal and the issue disappeared. Still I can’t conclude why it was stuck that way… The gumball should be working from any perspective or orientation, no? I guess since it’s gone I’m okay now.
