Hi McNeel
I can’t say if it’s always been like this, or if something has changed, but…
In the attached file there are 3 cylinders: first is open, second has a revolved cap, third is capped using Cap.
If I sub-object select the edge of the cylinder(s) using ctrl+shift, initiate extrude via the gumball and then - as the extrusion is underway - hold down shift to extrude both ways - only the open cylinder and the revolved cap results in an extrusion that goes both ways. The capped cylinder shows the corect preview, but the resulting geometry is only extruded in one direction. Bug or is there a reason for this?
gumball extrude bug.3dm (118.8 KB)
System Info
Rhino 8 SR29 2026-2-10 (Rhino 8, 8.29.26041.19001, Git hash:master @ 80d77ae009ea63d1508535f3c0798937283f5e68)
License type: Commercial, build 2026-02-10
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 95GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.6.1.0
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\RhinoBanana\0.1.9\RhinoBanana.rhp “RhinoBanana” 0.1.9.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26041.19001
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.29.26041.19001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26041.19001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.29.26041.19001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.29.26041.19001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.29.26041.19001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26041.19001
TIA, Jakob
