Gumball did not appear after selecting the object?
Hi everyone!
Why didn’t the gumball appear after selecting this object and completing the selection?
private void SelectByBox()
     var get = new GetObject();
     get.SetCommandPrompt("selectedObjects");
     get.SetCustomGeometryFilter(ConstructFilter);
     get.GetMultiple(1, 0);
     var objects = get.Objects();
     if (objects != null)
         foreach (var item in objects)
             _service.Doc.Objects.Select(item);
I have to execute the following code to re-display the gumball . Is there a better way?
 public static void ActivateGumball()
     Rhino.RhinoApp.RunScript("'SetRedrawOff", false);
     RhinoDoc.ActiveDoc.Views.Redraw();
     Rhino.RhinoApp.RunScript("'SetRedrawOn", false);
You’ll need to add 2 more true’s into your select to make sure it highlights in Rhino.
             _service.Doc.Objects.Select(item, true, true);
https://developer.rhino3d.com/api/rhinocommon/rhino.docobjects.tables.objecttable/select
thanks your reply, but I followed your instructions, but the gumball still didn’t appear.
This might sound daft, but I’d kick myself if I didn’t check.
Is your gumball turned on?
yes ,it’s on ,
@csykes
