Gumball cut creates invalid object bug
Gumball cut the blue circle like this:
2026-07-17_Fillet.3dm (433.4 KB)
I get an invalid object.
When I first extrude the circle and then do a Boolean Difference, the resulting object is valid.
Hi Charles,
Thanks for the file — I was able to reproduce the invalid result here. The cut leaves a bad trim on the cutter’s cylinder wall, right where the intersection crosses the seam. Extrude + BooleanDifference builds the cutter slightly differently, which is why that route stays valid.
Logged as RH-97059.
