I’m evaluating Rhino 7, so obviously a newbie, but noticed something odd with the gumball. After I go into the Rhino Options, Modeling Aids, Gumball and make a change, say Tip Width, then select an object in Front view, the Gumball axis colors are swapped and wrong. If I unselect the select again the colors are correct. I did not alter the RGB default colors at any time. It is not a big deal, I only posted this because it may be part of related issues that you are looking at. Behavior is repeatable, but if object is selected in Perspective View it is okay. I did not have time to test other views.
Version 7.12.21313.6341, 2021-11-09
Hi Lawrence - by default the Gumball uses CPlane axes, not World, so what you get depends upon what view objects are selected in. Does that make sense with what you are seeing?
Yes, I think that could be it.
