Gumball acts weird
Hi!
What is wrong with gumball it makes like this…
Is there any setting which is wrong or is this bug?
I tried to move upper surface up and the hole shoots to the zero…
Hello - can you post a file with that object? Making a similar thing here works fine…
Gumball.3dm (142.9 KB)
Hi Pascal, please check file :slight_smile:
is because of the cylinder , is slighlty trimmed. sub selection and edition doesn’t work well with trimmed surfaces, specially with trimmed cylinders. If you shrink the surfaces and untrim the cylinder. it works just fine
the bottom of the cylinder has a small cut
