Hey Pros,
Is there a way to use gumball in 45%. That would be very helpful when extruding a SubD edge.
Thanks much!
Hey Pros,
Thanks much!
DragStrength?
you can set the ortho angle to 45 then rotate the gumball
sorry I miss read % by degrees.
I just looked up ortho angle. I suppose I should get a 3 button mouse.
I’m sure this is easy after I get the basic idea. SetOrtho, just turns ortho on and off. What should I look up, or what command should I use?
right clic on the ortho label to set a different angle than 90 ( by default)
