Gumball 1-D Tranformation
Hello I have been using the gumball for scaling for years and it always scales in two directions when I pull on the handles.
Nevertheless, sometimes it scales in 1D. I am interested in having it scale 1D all the time. I have referred to this link: http://docs.mcneel.com/rhino/5/help/en-us/commands/gumball.htm
and cannot find a solution.
Any help would be greatly appreciated.
Thank you.
Erik
Hi Erik- Gumball scales 1d from its origin unless you hold Shift- then it scales 3d.
Hello Pascal,
Thank you for your prompt reply; however, it does not seem to scale in one direction for me. A curve always scales equally in both directions. See attached as it shows exactly what I mean.
Well- it scales in one dimension from the gumball origin- so you may need to move the gumball (RelocateGumball) or simply use the Scale1d command.
Understood. Thank you for the insight. I was confused about this.
Erik
