Gumbal not aligned to object
Hi @Gijs
In GumballAutoReset doesn't work you looked at a problem with me about the Gumbal AutoReset. I thought the Gumbal AutoReset was the problem but im not so sure anymore, because I’m still experiencing the problem.
My problem is that blocks in my file get there gumbal placement misplaced. This happens randomly. Could be at a block is fine one moment, work some more come back to that block and its misplaced.
In the image you see a fairly simpel block where Rhino suggests that the gumbal is above it. But in fact there is nothing there, call it a ghost. This block was exported to new Rhino and still its misplaced.
Ive scaled that block like a million times bigger because the gumball is over 200.000mm away.
If you run GumballReset it go’s back to its origin.
I’m really not sure what is causing this misplacement, not sure if its something is that I do or just Rhino8 bug.
Gumball placement wrong.3dm (386.4 KB)
SystemInfo
Rhino 8 SR8 2024-5-14 (Rhino 8, 8.8.24135.14001, Git hash:master @ 8c191427bc5c6c4e62f523a752d809f68897c3a5)
License type: Commercial, build 2024-05-14
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 3-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.30
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-8-2023
Driver Version: 31.0.15.3130
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.8.24135.14001
This is a hard problem, since there will be not much info in that file to determine what caused the displacement. @Joshua_Kennedy do you have an idea what might be happening here?
Like you said, GumballReset is putting that back to where it’s expected. When you relocate in any gumball mode the orientation is saved. Here’s the relevant issue for saving it in the 3dm file. Undo support for gumball relocate necessitated saving the orientation for all modes on the object. There’s a saved CPlane frame for that object in the 3dm file. So at some point maybe you relocated the gumball?
Hi @Joshua_Kennedy,
I do not move the gumball itself but I do use _GumballAlignment quite a lot.
Its also 200 meters, away, nothing in my file is even remotely in that position.
Also, its not just this file, or this machine. I have seen it on my home and work pc, and in every file I work on. big blocks, small blocks, linked blocks, embedded blocks.
I’ve had case that I reset-ed the gumball, exited the parent block, opened/blockedited the parent block again and it was moved again.
It wasn’t in Rhino 7, and I have been using the _GumballAlignment since RH6 already. I’m not sure anymore if it was in the first release of RH8 of that it came with a later release.
To me it really seems like a Rhino8 problem but I just don’t know what specifically is causing it.
@Martijn did you scale the block, or the objects in the block?
Did you do that so that it would be easier to see the block item? Do you also have the file before that scale was changed?
@gijs,
Yes, the block has an 8x8x60mm boundingbox. The gumball was so war away that you might lose the block also otherwise I couldn’t make a clear screen shot.
I’m not sure if this is the same block (position wise), but I exported it again. This time unscaled.
Also this when _GumballAlignment is set to object
Gumball placement wrong unscaled.3dm (384.5 KB)
@Gijs
Here is also a situation with a curve where the gumball is misplace.
Again I didn’t move the gumball, came back to the block and is was wack.
Curve with gumball misplacement.3dm (378.1 KB)
Do you model these blocks in different units than the file you’re importing them to?
i am experiencing same thing
@Joshua_Kennedy
Nope, always the same template and units (mm)
Thanks for staying with me and reporting this stuff. All these files show the same thing which is a saved gumball orientation in the user data already that’s being used. How it’s getting to the wrong spot in the first place is the question. If you can give me the step-by-step of what exactly you do leading up the orientation going wrong it would help immensely. I understand this can be tricky since it seems random. So far while investigating this I’ve dug up RH-82058 where scaling isn’t being applied to the saved orientation for block instances on import when unit systems vary.
Hi @Joshua_Kennedy,
I’ll try to keep an eye out for this problem this week, maybe I can see some kind of correlation.
We are running some pythonscripts, but our IT department has told me that the chance that its related to a script thing is almost 0% (especially since we didn’t have this problem in Rhino7).
@ivan.galik, maybe you can also help with tring to find out what is causing this?
