I have a guide on Floor 0, which I don’t want to be visible on Floor -1.
In order to do that, I gave the guide bottom elevation 0 and activated the “Clippable” > Section style “By Layer” option.
When I isolate Floor -1, in perspective view the guides disappear, but in Floor plan -1 they are still there :{ (of course it would be preferable if they would also disappear on the plan views).
Hi @Kida the VisualARQ Guides are dynamic objects that are used to draw and align objects across levels. They are not meant to reside in one level or in a specific elevation. If you check their style properties, there a few display options in the Model view:
But in the Top viewport or the Side viewports they are always visible. If you don’t want to see them guide in the top viewport, you can simply hide then manually or hide the layer where they are located.
The option to see them displayed in one level in the Perspective view, but not in the top viewport is not possible.
The Top and bottom elevations are used to place the labels in Side viewports:
