I can now reproduce another variation quite clearly. Please check the attached GIFs.
In Perspective, the Guide itself is selectable, but I cannot select its control grip.
If I switch to Top view, I can select and control the grip.
However, once the grip is selected and I try to move it, it does not snap to the geometry I need.
So in practice I still cannot reliably modify an existing Guide and accurately reposition its endpoint. I end up having to recreate the Guide.
Since some Guide control-point and snapping issues were already fixed in previous VA3 updates, could you check whether this is a different case?
Ideally, editing an existing Guide should work consistently regardless of the relevant viewport: select its control point, move/drag it, and use normal Osnaps to place it accurately.
I think this is particularly important because Guides are currently the main reference/constraint mechanism for keeping the model parametric.
Hi @GabrielB there are still some issues related to guides pending to be fixed. In some cases, the control points can’t be selected, as you have noticed. This may have to do with the display mode rather than the viewport, (usually in Wireframe mode it works), but we we need to analyze all situations with different examples.
In addition, we have noticed that when the cut plane is enabled in the top viewport, guides control points are not visible.
I could not reproduce this one, so please share a simple example where I can replicate this behavior.
The GIF I attached is actually the example I am referring to.
Once I select the Guide control point, I can move it, but I cannot accurately snap to that control point itself when trying to use it as the reference point for the Move operation.
So the problem is not only selecting the grip, but also being able to use it reliably with Osnaps, just like a normal Rhino curve control point.
Am I missing something in the intended workflow? Maybe I am in another sub-level, but on the other hand, those guides are configured by style to be visible managagable on every level (and on sub-level too I suppose).
If you can share a file I can test this with, it will be useful to figure out if there’s a setting that is affecting this, or if it is a specific file problem.
