Hi
This bug somehow sneaked in at some release of rhino 5 and I’ve noticed it’s still there in V6. Or is it just me having groups getting ungrouped in blocks? (once reediting a block or exploding it, the group is gone)
Best
Aurel
Hi
Best
Aurel
Hi Aurel - groups do not survive blocking - I don’t think they ever have - Hmmmm. Groups are essentially nothing more than saved selection sets and the set is a bunch of object ids - as far as I know there is not much more to it than that. A block definition would need to keep group information and transmit it to each instance and, I guess, the instance would have to implement the group on Explode or BlockEdit when the new objects are added to the file .
I imagine this is possible but probably not straightforward…
Hi Pascal, thanks for your answer. I could get used to blocking in blocks. Groups are just so convenient and fast, it seems intuitive they would survive blocking. Funny that I remember doing that in earlier versions, but i might be wrong!
Hi Pascal,
I see that here you already discussed the issue of grouping within blocks.
I wonder if not more people would find this very helpful.
Currently, I would have enjoyed this feature greatly. For example when you have any repeating objects ( in my case wood battern) but you cannot conveniently use the layers as you dont want to change all of “wood batterns”.
So i was wondering if implementing this feature is still not a topic.
Thanks a lot.
-N
Hi - I’m not sure what that means. Can you give a specific example in a 3dm file?
I meant that the selection of objects with layers makes no sense (in some cases) because I would have to create one for each “group of object”
in the enclosed file I want to change some wood (eg. one quater of a circle) then it is very painful to select the items. Hope its more clear.
Thanks
-N
Untitled.3dm (1.4 MB)
