Grouping range of points
Hi guys,
I’m trying to find a way to group sets of points and the set needs to be (controllable range).
like the group in rows of 4 in the image, if the number of points is not 4 then no group.
any idea?
tried to use series with list item but not really sure how to approach after
points group.gh (10.8 KB)
points group_2024Mar19a.gh (21.7 KB)
Jittering the branch colors:
P.S. Oops, reversing the output of Partition is pointless…
boom nice, question Is the orientation of the point groups due to renumbering? is it possible aslo to jitter this value top and down ?
No, you can toggle the Tree Branch component to disable renumbering. If you un-reverse the Cull Pattern component output the groups will be at the bottom of each column instead of the top. Disable preview on Cull Pattern to see only the groups of four.
Don’t know what you mean? Jittering the branch colors has no affect on point positions.
The point selection goes up ,like hierarchy . is it possible to shift these values so it also picks some groups from the bottom? Like the image attached
Sounds like an art project. Many things are possible when you understand the code.
points group_2024Mar19b.gh (27.1 KB)
Thanks joseph! This what i was looking for,
Your codes are really simple cool man!
