Is there any way we could add a ‘Group Result’ option when creating Arrays of objects? That way you could pick the group of resulting objects with one click, instead of having to select them individually. Would be really useful.
thanks,
david
thanks,
david
have you tried the command _SelLast
? it might be helpful here.
• make the array
• SelLast
• (maybe shift/select the original object if it’s been omitted from the selection)
• ⌘G
that way is probably a lot speedier than needing to select each object individually…
you could automate it further with a macro
Thanks Jeff, that’s a good workaround. Looks like there’s already a macro button for that in the Select toolbar.
cheers,
David
