Group of breps vs polysurface
I wonder what are the differences between a set of breps joined as polysurface or the same set joined as a group.
Does a polysurface have a unique id (and a group several ids)?
Can one attach a single instance of ON_UserData to a whole group, like with polysurfaces?
Also, when a single brep is modified, does its whole corresponding polysurface have to be replaced (but not the whole group)?
Thanks,
Pablo
Hi @pagarcia,
A surface is a Brep with a single face. A polysurface is just a Brep with more than one face. Both objects are represented in Rhino as a CRhinoBrepObject.
Just one
Yes, you can attach user data to a CRhinoGroupObject and/or an ON_Group.
Yes
– Dale
Hi @dale,
How can I select and attach user data to a group? I tried the following:
CRhinoGetObject go;
go.SetCommandPrompt(L"Select group");
go.EnableGroupSelect(TRUE);
go.EnableSubObjectSelect(FALSE);
go.GetObjects(1, 0);
if (go.CommandResult() != CRhinoCommand::success) return go.CommandResult();
for (int i = 0; i < go.ObjectCount(); i++)
	const CRhinoObjRef& obj_ref = go.Object(i);
	const CRhinoObject* obj = obj_ref.Object();
	if (nullptr != obj)
		const CRhinoGroupObject* groupObj = CRhinoGroupObject::Cast(obj);
		if (nullptr != groupObj)
			RhinoApp().Print("Selected group\n");
			//Do something with this group, attach user data, etc
The code above seems to properly select groups, but the objects referenced by the GetObject getter are the ones belonging to the group, not the group itself. So I can’t cast CRhinoGroupObject
Pablo
Hi @pagarcia,
See if this helps.
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
  CRhinoGetObject go;
  go.SetCommandPrompt(L"Select grouped objects");
  ON_SimpleArray<int> indices;
    if (nullptr != obj)
      indices.Append(obj->Attributes().GroupCount(), obj->Attributes().GroupList());
  // sort
  indices.QuickSort(&ON_CompareIncreasing<int>);
  // cull
  int index = -1;
  for (int i = indices.Count() - 1; i >= 0; i--)
    if (indices[i] == index)
      indices.Remove(i);
    else
      index = indices[i];
  const CRhinoGroupTable& groups = context.m_doc.m_group_table;
  for (int i = 0; i < indices.Count(); i++)
    index = indices[i];
    if (0 <= index && index < groups.GroupCount())
      const CRhinoGroup* group = groups[index];
      if (nullptr != group)
        RhinoApp().Print(L"Group %d = %s\n", index, group->Name().Array());
  return CRhinoCommand::success;
– Dale
Great, thank you @dale !
To attach user data, I use ON_Group::AttachUserData(ON_UserData *pUserData) over a duplicate of the group and calling
context.m_doc.m_group_table.ModifyGroup(const ON_Group& group, int group_index)
with this duplicate as input and the index. Hope this is the right way to do.
Pablo
