Group manager?
Hello!
Is there a group manager in rhino?
I see a few references to an Object Manager panel but not seeing this in Rhino 8 and the youtracks are still open.
Here are the available group-related commands:
  • Group - Organize selected objects into a single group (ref)
  • Ungroup - Remove group status from objects (ref)
  • AddToGroup - Add an object to an existing group (ref)
  • RemoveFromGroup - Detach objects from their parent group (ref)
  • SetGroupName - Name a group (ref)
  • SelGroup - Select a group by name (ref)
Group management is command-driven rather than panel-driven, unlike blocks. If you are using the object more than once a block offers a lot of possibilities. Group is just a selection set and is unique.
Thank you. I found groups are too limited for my use case and finicky in such way that if you have 3 lines in one group and 2 of these lines at the same time in another group, clicking on certain line might select all 3 or only 2.
Its undesired behavior for my use case, so I switched to blocks instead. Which has its own challenges.
