Group bug, added everything into one group
rhino
(Akche001) #1
Made first group, made another group. Everything added into one group.
Group bug.3dm (54.7 KB)
Group broken in latesr srC
(Pascal Golay) #2
Hello - thanks, I see this…
https://mcneel.myjetbrains.com/youtrack/issue/RH-44056
@akche001 - can you please tell me what build of Rhino you are running? Run SystemInfo in Rhino and copy/paste the first line here. Thanks.
(Akche001) #3
Thanks Pascal!
(Akche001) #4
Sure
Rhino 6 SR2 2018-2-7 (Rhino 6, 6.2.18038.4101, Git hash:master @ a558313bc402d40d17bdf4500977c08ab6e465e4)
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
GeForce GTS 450/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 390.77)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-23-2018
Driver Version: 23.21.13.9077
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
(Pascal Golay) #5
Thanks. Looks like it is only an SR2 bug so far.
(Akche001) #6
Yes, exactly. No problem with previous release.
#7
I noticed this behavior in rhino5 when I use rhinoscriptsyntax to copy or translate objects in a group. They always end up in the same group. I don’t know if this is normal or not.
objs = rs.GetObjects("select a group of objects:")
rs.CopyObjects(objs, [0,0,3000]) #the copy will become part of the group
(Pascal Golay) #8
Hi Bogdan - Yeah… I think this is probably at least ok in scripting - you have the control in the script to handle it.
x = rs.CopyObjects(objs, [0,0,3000])
for id in x:
    rs.RemoveObjectFromAllGroups(id)
y = rs.AddGroup()
rs.AddObjectsToGroup(x,y)
The bug in 6.2 appears to be that all added groups are called the same thing, which makes them all one group. In the script, whatever group memberships the objects have are kept on copying. That might or might not be the right thing to do but as far as I can see it is a different problem…
(Rob) #9
Same problem here latest release candidate, making 1 group , and then making another grouip makes it 1 group, not handy
(Akche001) #10
That’s what this topic is about, RC (6.2.18038.4101, 07/02/2018) problem.
#11
Thanks @pascal
The problem complicates easily if, for example, I have several groups and need the copies as several other groups, or even worse, if I have groups inside groups.
(Akche001) #12
This bug is not smashed in (6.2.18043.22301, 12/02/2018) and it’s annoying. :roll_eyes:
#13
Dito
(Pascal Golay) #14
Hi All - this was fixed yesterday - the next 6.2 RC should have the fix.
(Brian Gillespie) #15
RH-44056 is fixed in the latest Service Release Candidate
