I’m rendering a boat and I want the Ground Plane (water) to fade out smoothly into the HDRI environment horizon.
I have applied a radial transparency texture to the transparency map, as you can see in the image below, but I can’t get it to work. My goal is to find a more efficient way to blur that solid horizon line, which currently looks very sharp and unrealistic.
Do you know of a better way to make the horizon line look softer and less marked?
You’re on the right track. The problem is the ground plane object is a weird one. It is infinite so the UVs for the blurred texture to create the alpha fade won’t work. Check out this example instead using a large plane. The noise texture uses WCS for the Bump but the Alpha uses the the default Surface UVs. You can scale the plane itself to adjust the effect or make a new blur image for the alpha. You could additionally use focal blur/depth of field.
Thank you so much for the help and the example file. It worked perfectly! Using a large plane instead of the Ground Plane allowed me to correctly map the radial transparency and finally get that smooth transition into the HDRI horizon.
The tip about using WCS for the Bump and Surface UVs for the Alpha was exactly what I needed.
2,000,000 units LOL… not infinite true but for all intents it might as well be. The texture mapping control is also unique for the GP making this use case impossible as far as I see.
If modelling in millimetres, that’s less than half way to the horizon for an adult standing at sea level and looking out to sea. Long way from infinite…
