Grooves in grasshopper
Dear all,
I’ve been trying to make grooves on the first line but I’m not giving the right command. Assistance appreciated.
Red line indicates grooves at equal intervals
Regards
I would first make that shape into a surface using the boundary surface component. I would then divide that one line into equal segments (3 in this case), then create a box volume with x and y dimensions the size of the groove you want. The z dimension can be anything above 0. You could then do a solid difference to ‘cut’ the grooved into the surface.
@works.satyajit posted the same task as you do. Are you guys in the same class?
What a coincidence. That shape is quite similar to mine.
Small world.
:slight_smile:
I was about to ask if there’s some competition or something to create this :smiley:
