Grips for holes?
Hi there,
I would like to ask if it is possible to modify a planar surface by its grips. I created a planar surface by the Planar Curve Command but the hole does not have grips. Is there other way to modify the planar surface to also retain the hole in the same position?
planar grips
I think the SolidPtOn command should work here…
Thank you, this was that I was looking for…
