Hi there, can anyone help me with the macro to set up toggling grid snap on and off?
I used to have it, previous plugin and previous Rhino version.
I’m setting it to Ctrl Q.
Thank you very much.
the online help is a nice ressource for those questions.
Snap
Shortcut → F9
Alias → S
Alias
you will find alias as section in
_documentProperties
Alias can not have hotkey-kombination (alt, cmd, shift…), but multiple Characters.
for example you can assign BD for BooleanDifference.
you can see them more as a easy to remeber, short Nic-Name.
Aliases will Auto-complete in the command-line and will be at Top of the list.
shortcuts
you will find shortcuts as section named Keyboard
_documentProperties
with Shortcuts you link a specific macro to a single Keyboard Input / Key-Kombination.
(that are already defined)
and of course you can edit / customize both of them
please update your title:
Grid Snap toggle on and off Shortcut
so others find it more easy
please mark this post as solution if it solves your question.
Thank you Tom, I have looked at this previously, but I was after toggle on and off with the same set of keys (say, Ctrl Q).
I just need the words for the macro for snap toggle on and off. Can you help with this?
Kind regards,
Helen Pusenjak
CAD Jewellery Designer
DesignDrawCAD
0409 600 765
_Snap
(it’s a toggle). You might also want to look in Options>General>Never repeat these commands
, and if it is in the list, remove it from there.
Ah! That’s it, simpler than I thought.
Also the Never repeat is something I never knew about so fantastic!
Thank you very much, Helvetosaur!
Kind regards,
Helen Pusenjak
DesignDrawCAD
0409 600 765
