If I have a display mode in which the grid is set to Use Mode Specific Settings, Show grid is not checked, and Grid Appearance is set to Show grid on top of objects, if I have an object below the grid, the grid will show on it even though the grid should be off. Probably for @jeff
Probably best to just post your mode…because setting up a mode that does what you’re saying here seems to work…but there are soooooooo many more options in the display modes (: So I’m not going to try to second guess what others you’ve set.
You were right, there was another needed ingredient, advanced GPU lighting. Attached is the ini and a 3dm which over here illustrates the problem.
Sam
(Interesting, I tried to capture it using ViewCaptureToFile and what I’m seeing didn’t show up in the capture. This is a Ctrl + C of it where it does show up)
