Grid for printing with plans..how?
V5
Is there a way of auto generating a grid, with numbers maybe 0 10 20 30 across it and indication of mm or cm, to have as a light grey in the background to allow accuracy check of printed out plans. every 10 lines a bit bolder, just as in background.
In fact to be able to take the background grid and make it printable would be good as an option.
I have created one in Rhino but now find myself having to add to it for a larger item and alter the numbers to where I need the origin again.
How can I get my grid to NOT get printed over the top of objects ?
Steve
Try SendToBack, SendBackward, BringToFront, BringForward. Or maybe try moving the grid behind your objects…
Here’s a file that might, or might not, help - you can import it and scale to taste, the numbers will update.
Grid.3dm (107.5 KB)
Cheers Pascal,
I had created a grid looking very much like the default background which I saved as a 3dm.
Whilst I am seeing greys on screen for this grid of mine, they are not cmyk values or tints of black. How can I dictate the shade of grey they will be when printed ? I wont be overseeing the printout and even if I was, I wouldn’t want to have to go home redo and try again.
Steve
@pascal You still got this file somewhere in your archives…? :slight_smile:
Hmmm- not so far…
Can’t wait to see your avatar w/o the mask!
If this is still available, I’d like to try it.
Here you go , I dredged it up…
@Alan_Farkas , fyi…
Grid.3dm (78.9 KB)
Wow! Thanks Pascal.
Thx so much! Looking forward to giving it a whirl!
