Grid Distribution Adjusments
Hi @mmakki_10 and @milad.showkatbakhsh ,
When I tried to distribute to the grid after exporting solutions, my results were so small on the grid. How can I reduce the dimensions of grids? Furthermore, I want to also show the values of my optimized genomes for each phonetype within the grid. For example, I want to see the optimized values of the cross section of my shell. How can I do that?
Thanks in advance,
son wallacei shell analiz.gh (99.4 KB)
there is an input for grid dimension. In your file you inputted 99, obviously it made it disperse and your solutions will be small. As for the optimised genes, you can decode them and then plot them next to each solutions. You will find out how to do these things in our YouTube channel.
Thank you for your reply.
I have another question about bake of results. When I bake the grid distribution, I can’t see the fitness values and generation numbers below the geometries. How can I fix it?
When I try to give transparency to my meshes in Grasshopper to show values as in your YouTube video, my geometries seem so black after baking. Is there any other way to keep geometries and fitness values simultaneously after baking?
Bake with the middle mouse button and you will also get the texts baked.
