Thanks, Dan!
Sidenote: the Grasshopper window disappears when it becomes inactive, it won’t stay on top of Rhino, should I start a new topic for that?
Thanks, Dan!
I can’t seem to reproduce this on macOS Mojave (10.14.1) and the latest RhinoWIP. What are the exact steps you are taking?
Also, can you please run _SystemInfo
and attach that here?
Hi Dan,
I’ve taken a screen recording. Nothing special, open up RhinoWIP, type Grasshopper, and that’s it.
Maybe we are not talking about the same thing (at the time of posting it’s still uploading):
To rephrase the issue, by the “Grasshopper window disappearing” I mean, that I would like to have it as in v5 for Mac (or in the Windows version): no matter what I do in Rhino, if the Grasshopper window is open, it always stays on top.
My system info:
Rhino 6 SR12 2018-11-6 (Public Build, 6.12.18310.10526, Git hash:master @ 796297cb9cb110b9a02b7734498c64c8583a4eb8)
Licence type: Beta, build 2018-11-06
License details: Cloud Zoo. In use by: furtonb ()
Expires on: 2018-12-21
Apple Intel 64-bit macOS Version 10.14 (Build 18A391) (Physical RAM: 16Gb)
Machine name: fb’s MacBook Pro
Language: en-HU (MacOS default)
AMD Radeon R9 M370X OpenGL Engine (OpenGL ver:4.1 ATI-2.0.36)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Driver Date: (null)
Driver Version: (null)
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Displays: Color LCD (295dpi 2x)
Screen size: 1920 x 1200
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
at.obdev.nke.LittleSnitch (5207) 9FEE069A-6B44-395D-B154-411C856CB951
Third party plugins
None
Rhino plugins
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 6.12.18310.10526
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 6.12.18310.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 6.12.18310.10526
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 6.12.18310.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 6.12.18310.10526
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 6.12.18310.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Alerter.rhp "Alerter" 6.12.18310.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 6.12.18310.10526
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp "Displacement" 6.12.18310.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 5.1.2015.132
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp "Rhino Render" 6.12.18310.1002
Same behavior here - Grasshopper window does not stay in front of Rhino window as it did in previous versions. I haven’t upgraded to macOS Mojave yet (still running High Sierra).
Ah thanks @furtonb. A video was worth at least 200 words Yep, this is a regression after the big VB merge. I’m reopening RH-36851.
This should be fixed in the latest RhinoWIP. Please give it a try.
I’ve checked briefly, it is fixed. Thanks!
This has been bothering me a lot, so I downloaded the WIP version, but this is still happening for me. When I use “Check for Updates” it says I have the newest version (6.14).
Is this not the latest version? Do I have to change any settings for this to work?
Thanks, Daniel
OK, I read this through and watched the video again, and maybe I am talking about a slightly different issue?
My exact problem is that I am working with several applications at once (but mostly I connect GH and Rhino to ARCHICAD), and so I have Rhino and GH open on one of my screens, and my other apps on my other screen. When I switch to any other application from Rhino, the GH window disappears, and only comes back when my active application is Rhino again - so I can’t go to my other applications and see my GH definition at the same time - which would be crucial for me. This works absolutely fine on Windows.
Is this a different issue? Can/will this be fixed?
Thanks
Yes, this is a different issue.
A developer is looking into this - you can follow progress here: RH-50695
Wow, that was fast, thanks!
The site you linked says I don’t have permission to view it. Do I have to register anywhere?
Thanks,
The issue was originally set to be visible to developers only - it’s now open to the public.
