Grasshopper - Weave
Sorry, I got stuck with something very simple.
Any hints, much appreciated.
Hello
it would have been welcomed if you posted your code.
You could also read the help, pattern is not true or false
You ca do that or that
Indeed StreamGate could have been the solution but it works just with one index.
multiple stream gate.gh (8.3 KB)
Use pick and choose instead…
pick-and-choose.gh (7.8 KB)
in the particular case of the OP I think simply connecting the booleans panel to a Integer capsule and then connecting it to Weave would work just fine.
I don’t think so, documentation seems clear. Number of output >= Sum of Number of Inputs
@martinsiegrist answer is the best solution.
thanks so much, everyone!!
