I am trying to add transformations together using the compound tool.
The tool does appear to accept multiple connections.
Is there another way to work around this?
I suppose there’s a missing “not” in your post (?).
If so, you should hold down the SHIFT-key while adding connections, then it will work as designed.
// Rolf
Thats great, thank you.
