Grasshopper text
Hello everyone,
I’m working on a Grasshopper definition in Rhino 8 for a engraving / CNC / laser cutting workflow.
My goal is to:
  • Import text strings (for example from an Excel file)
  • Generate text as curves in Grasshopper
  • Accurately center each text on a given reference point (Rhino point or point derived from geometry)
  • Apply transformations such as scaling or mirroring if needed
  • Project the text curves onto a surface (flat or slightly curved)
  • Finally, bake the curves in an organized way (by layers) for manufacturing
The key challenge for me is the precise centering of the text:
:backhand_index_pointing_right: I’m looking for a reliable method to ensure that the geometric/visual center of the text aligns exactly with a target point, regardless of text length, characters, or font.
I’m open to:
  • native Grasshopper solutions,
  • text-related plugins,
  • or alternative approaches (scripting, different workflows).
Thanks in advance for your help and suggestions.
You can start the process by uploading a Grasshopper definition of what you have so far…
Do you have Rhino 8?
Hello Martin,
Yes, I am using Rhino 8. Unfortunately, I am stuck in Grasshopper. I should mention that I am a beginner with Grasshopper.
At least you know you don’t really need Elefront when you have Rhino 8.
Are you aware ther’s a search function in this forum?
Surely there will be a plugin that solves the issue more simply.
text.gh (32.7 KB)
this can be done with annotation style settings
