is it possible to determine the position of the sun not for a specific time range but based on certain angles, for example, everything above 11 degrees?
Thanks a lot!
Kind regards
Using Rhino 8, here is the sun pushed into Rhino by Date and Time, but then extracted using Azimuth and Altitude Angles:
Hi @scottd ,
thanks for your response. I would like to use the LB Sunpath, to do a direct sun hours simulation. As a weather file i use an epw file. And the simulation should only be carried out for sun positions above 11 degrees. I don´t know, how i can connect this right now.
Best regards
Hi Christian -
For questions about the Ladybug Tools, please use https://discourse.ladybug.tools/
