eobet
(eobet)
#1
I generate a set of intersections from two curves I have in Rhino:
But after using the gizmo to move the line a little bit, it looks like this:
Does anyone know why? If I change the pattern count, all points most often come back, but not always. This seems glitchy over all.
intersect.gh (8.5 KB)
intersect.3dm (92.4 KB)
jeremy5
(Jeremy)
#2
Works fine here. Run the systeminfo command in Rhino and see if you are running old and/or Intel graphics drivers.
tim.stark
(Tim Stark)
#3
What’s your your rhino tolerance?
eobet
(eobet)
#4
I’m using pretty new nvidia drivers (updated after the security hole got fixed recently).
You’re not able to move the line in the Y-axis so that only one point is showing?
jeremy5
(Jeremy)
#5
No, regardless of how big or small a move I make I can’t replicate the problem.
I’m running yesterday’s service release candidate for R6.15
