Grasshopper shape and folded origami
Hello I have to make a folded origami like object using grasshopper And in order to achieve the folds I want it would have to be the shape in the picture below. Does anyone have any suggestions on how I could make this shape using grasshopper?
Hi Felicia
Could you post the file? It’s hard to understand what your goal is based on the image. (it looks like 3D, but it’s on a C-Plane, confusing)
Kaushik LS
Chennai, IN
The goal would be to create something like this right now it is on a cplane. I am trying to use possibly grasshopper to help achieve this shape. I will attempt to attach the file.
image image
model try.3dm (115.8 KB)
As a start you could make a mesh with faces for each of your triangles using the 3DFace command in Rhino.
Use Join to combine these triangles into a single mesh, then turn on the control points and move them out of the plane to get the shape you want.
Thank you I’ll give it a try!
