I am using a plugin called “Wallacei” which I use to create some Geometry with a GA. I want to automate the process, so that I dont have to open up the plugin everytime and put in the parameters. I though it would be possible with the Grasshopper SDK to trigger it with some parameters previous set. But I cant find how to access a installed plugin through C# with Grasshopper. Is it possible?
Thank you
Cheers
