Hi. I was wondering if it is possible to make a script in grasshopper that makes a srf with a given pattern based on lines/curves drawn in rhino? I’ve only managed to make it with louvres, but not with a whole srf (i’m working on making a facade)
I’ll put some pictures of what i am trying to explain. If someone could help me with this I be greatful.
The curves are done with magnetic fields components in native grasshopper or using certain plug ins:
Check FlowL
Or these posts
For the 3D part I am not quite sure if they are using meshes or nurbs, but in any case the logic has to do with using the curves as attractors to modify the geometry.
Because of the complexity of the geometry I would think it has to do with meshes/quadmeshes/subd
Specially given this detail here clearly pointing to a resolution topology:
