Grasshopper/Rhino SDK - How does one get the name of the current open file from an External Application?
I do know how to use the COM interfaces to manipulate Rhino and also how to get the the Grasshopper plugin COM interface so that I can manipulate Grasshopper.
I would like to know if there is any way using this method to get the name of the file that is currently open in Grasshopper - not in Rhino.
I am also comfortable to create my own Rhino plugin so that I can use it to get this information.
But, for that, I would have to know how one can get the Grasshopper filename of the currently open document from within Rhino. (I know that you can call Rhino functions from a Grasshopper custom component, but I don’t know if it is possible to do the other way around).
Thank you for the assistance!
I guess you’re looking for Grasshopper.Instances class:
import Rhino
import clr
clr.AddReferenceByName("Grasshopper")
import Grasshopper
gh = Rhino.RhinoApp.GetPlugInObject("Grasshopper")
if not gh.IsEditorLoaded():
    print "Grasshopper editor is not loaded"
else:
    for doc in Grasshopper.Instances.DocumentServer.Document:
        print doc
If you only want to get the active document you can use:
Grasshopper.Instances.ActiveCanvas.Document
GrasshopperDocuments.py (301 Bytes)
Hello!
Thank you so much. I did manage to put this inside a function of my custom COM plugin.
This function runs within Rhino, gets the data and then transmits to my client application.
Thank you again.
