Can we please get the option to export *.3mf with the Grasshopper Rhino Export Model Block Definition component?
Hi Martin -
I’ve added this thread to RH-71542 Create Export Model component in GH1
I logged this for the Export Model Block component:
RH-90722 Export Block does not support 3MF
Export works now but the imported geometry does not have a useful name
‘^(null)’
export_3mf.gh (13.1 KB)
test.3mf (357.2 KB)
Are you getting object names out of the 3MF Save As out of Rhino? I do not see them.
What app are you using to test 3MF results?
I don’t get names when exporting from Rhino.
The example file in the viewer shows a name.
So, I think that is the bug. The 3MF file format itself. I will get it reported.
Thanks for the detailed information and samples.
I’ve used GrabCAD a while ago to set up a print with overlaps and priorities.
Here the part name is ‘Default’ for all parts. It would be useful to have names, for sorting and quicker selection…
I modified a *.model *.xml file from an unzipped *.3mf and zipped the files into a *.3mf again. Imported in Rhino, the objects has the name I set.
named.3mf (299.3 KB)
The name also appears in the Online 3D viewer
As an addition, I was wondering why I can’t export multiple block instances into a *.3mf file?
Here’s my definition. The export also failed in Rhino. According to *.3mf specs, instance export should work.
export_instances_3mf.gh (21.6 KB)
This if what I get with the example script:
There are multiple blocks in the result. But, what would you expect it to be? is it a naming thing?
I think if there are multiple instances of the same block then they should not get renamed in the 3MF?
Not sure what the issue was with this 18_instances.3mf export yesterday, it worked fine now.
Would be nice if the instances also had object names.
I added individual names for the blocks in my export definition
export_instances_3mf.gh (23.8 KB)
We are making some changes, so we will see if we can get the naming right.
Since we are looking into 3MF code at the moment, let’s continue our conversation on how assemblies and blocks should work.
I forgot about the linked topic. Feel free to delete or merge…
Trying to.figure out if all objects need to be in a block, or if blocks geometry should be saved alongside blocks?
I think this works now
