Hello, I use solid difference to identify the displacement of hulls at assigned water lines and calculate the volume. Well, I measured a sold difference time in gh/rh7 nearly ten times slower than in gh/rh5 (in an example 1.4 seconds VS 170 ms). Does anyone experienced that? I don’t have rh6/gh6 to check also there.
Here in attach a simple test example (I cannot share hulls). It happens with polysurfaces with many surfaces: in this case RH5/GH5 is 4 times faster than RH/GH7!
testdif2.gh (430.0 KB)
my pc is far from being the best one on the market [i7-6700K]
are you experiencing much different calculation times in V7?
Ryzen 3900x and latest R7.
I’m currently on an old FX8350 … it takes
- 2.4 sec on RH7
- 2 sec on RH6
Can’t test on RH5.
to @inno and @DanielK1 , a useful info would be if you executed the same thing also on RH5…
Rhino 5 4 times faster than 7
my pc :
