Grasshopper remove line with word from g-code
working in rhino 7
remove line from g-code.gh (9.9 KB)
trying to write a ghpython script to remove any lines with a word in it
What am I doing wrong? … please help
right click on the text input panel and deselect multiline data
rename a to Output
Thank you @adel.albloushi, what do I need to do to maintain the multi-line data?
I think it should work.
But you’ll get null/empty outputs which you’d need to cull
Now I’d like to cull the empties from within the script but I get an implicit Grasshopper cycle error
def remove_word_lines(gcode, word):
lines = gcode.split(‘\n’)
cleaned_lines = [line for line in lines if word not in line and line.strip() != ‘’]
return ‘\n’.join(cleaned_lines)
Input parameters
gcode = Gcode
word_to_remove = WordToRemove
Call the function to remove lines containing the specified word
if gcode is not None and word_to_remove is not None: # Check if inputs are not None
cleaned_gcode = remove_word_lines(gcode, word_to_remove)
else:
cleaned_gcode = “” # Provide default value if inputs are None
Output cleaned G-code
Output = cleaned_gcode
Any idea how to fix it?
Can you upload the gh file itself?
It’s also helpful to have a bunch of typical text you expect to feed into the python component
anyway, here’s the fixed gh
remove line from g-code[fixed].gh (12.1 KB)
@adel.albloushi Thank you!
