Grasshopper Quick Image Viewport Frame orientation
Would it be possible that the Viewport Frame is perfectly aligned with the grid by default?
I know I can drag it but I’d prefer a nice alignment by default.
It is just slightly off and it was the same also in Rhino 5.
Hi Martin -
In a quick check, the placement of that image is remembered between sessions. Also, it’s not aware of components on the canvas and will cover those in many cases. Any default position will thus be wrong and the frame is likely to have to be moved no matter what.
That said, I suppose it would be possible to rethink this in Grasshopper 2, but, at this point, I don’t know if that feature will be in the new version at all…
Thanks for the quick reply. I’m not expecting a default position. The default alignment completely horizontal would be nice though.
What I was trying to say is that the default position and orientation will only be used one single time - the very first time that you create a quick image. In 99.99% of all cases, the user will move the frame at that point - and the orientation will be entirely in the hands of the user.
Yes but you can tap shift and keep the orientation perpendicular.
I don’t want to eyeball the alignment.
