Hello, here is my first post, beeing new to Python but rather skilled on Rhino and Grasshopper.
My project is to automate import of large number of iGES files, made of many surfaces. That I need to join in polysurfaces. I then need to store them in different layers and sublayers.
I found how to code in a GH Python Component the importing of files and joining the surface objects, but the moving to layers does not work.
I am stuck with this for hours… My research on Forums and web seem to show that ObjectLayer may not work in Grasshopper, but no clue on how to achieve this…
Many thanks for your help.
I have following error code Runtime error (TypeErrorException): Parameter must be a Guid or string representing a Guid
Traceback:
line 890, in coerceguid, “C:\Users\d3h\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\utility.py”*
line 1062, in coercerhinoobject, “C:\Users\d3h\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\utility.py”*
line 910, in ObjectLayer, “C:\Users\d3h\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\object.py”*
line 23, in RunScript, “”*
Here is the code in GH component:
from ghpythonlib.componentbase import executingcomponent as component
import Grasshopper, GhPython
import System
import Rhino
from scriptcontext import doc
class MyComponent(component):
def RunScript(self, LayerPath, igesfile):
__author__ = "d3h"
__version__ = "2021.04.29"
import os
rs.EnableRedraw(False)
rs.Command('_-Import "{}" _Enter'.format(igesfile), False)
NewObj=rs.Command('_SelLast')
if NewObj:
#Join surfaces in a Polysurface
NewObj_Join=rs.Command('_Join')
rs.ObjectLayer(NewObj,LayerPath)
rs.EnableRedraw(True)
return a
Looks like you need to change the script context to the Rhino document:
Also, welcome onboard We generally encourage people to follow these directions when posting (i.e. attach a Grasshopper file with your GHPython code that we can help you debug):
Hello, and Thanks for your prompt answer.
Make sure I will try to follow the rules.
Anyhow, I have implement what you suggest.
I don’t have any error message now, but my component does no longer do what I’m expecting, meaning importing the IGES file, joining the surfaces inside and send them to the required layer.
I’m sure I did not put all this together in the right place… Can you help again?
here is the new code:
tests_gh3_creation_calques.gh (14.4 KB)
import System
__author__ = "d3h"
def ObjInLayer(LayerPath, igesfile):
import Rhino as rc
import scriptcontext as sc
import os
# Set context to Rhino document and disable redraw
sc.doc = rc.RhinoDoc.ActiveDoc
NewObj=rs.Command('_-Import "{}" _Enter'.format(igesfile), False)
#NewObj=rs.Command('_SelLast')
if NewObj:
rs.Command('_Join')
#rs.Command('_SelLast')
#print rs.SelectedObjects()
if NewObj_Join:
ObjInLayer= rs.ObjectLayer(rs.SelectedObjects,LayerPath)
# Set context back to Grasshopper
sc.doc = ghdoc
ResultOK=ObjInLayer
# return outputs if you have them; here I try it for you:
return ResultOK
