Rhino 8.32.26160.13002, macOS, Apple Silicon.
Diagnostics already done:
- Runtime
py39-rh8fully deployed (163 MB), binarypython3.9 --version→ OK (3.9.10) - No Gatekeeper quarantine on the binary (
xattrshows onlycom.apple.provenance) PYTHONHOME/PYTHONPATHboth empty (no interference from system Python)- Root cause identified:
CERTIFICATE_VERIFY_FAILEDin the embedded Python (no valid cafile) —ssl.get_default_verify_paths()points to a non-existent/Library/Frameworks/Python.framework/Versions/3.9/etc/openssl/cert.pem - Fixed via certifi +
SSL_CERT_FILEenv var (set throughlaunchctl setenv); testurllib.request.urlopen('https://pypi.org')→ returns 200 launchctl getenv SSL_CERT_FILEconfirms the variable is inherited, Rhino launched viaopen -a "Rhino 8"
Despite all of the above, and after a full purge/rebuild of ~/.rhinocode, the language server still does not start: log files stay at 0 bytes, and no python process is active (checked via ps aux). The runtime deploys completely but the interpreter never comes up when I drop a Python 3 component.
What should I look at next? Any idea @eirannejad ?
Thanks
